Upgrade Freon 134a 1991 300E? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-18-2011, 10:26 AM Thread Starter
Date registered: Dec 2009
Vehicle: 1991 300E with 2.6 engine PLUS 1982 300SD
I'm considering replacing my R12 with the newer 134 Freon. Anyone experience issues with this like less cold or compressor design doesn't like R134 etc?
Have 1991 300E with the 2.6 engine. Currently zero cold air. I found shop that will convert valves and add 2 lbs of freon for $150, but no guarantee this car will like it.
jamescruz is offline
post #2 of 2 (permalink) Old 10-18-2011, 08:44 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is online now
    ML A/C freon(134a) rcharge question sparky1016 W163 M-Class 6 03-14-2011 12:42 PM
    300E - recharging the freon in air conditioning margaretia W124 E,CE,D,TD Class 15 02-22-2010 02:35 AM
    Is this where I add 134a freon (refrigerant) to my 300SE? Brythonic W126 S,SE,SEC,SEL,SD,SDL Class 9 04-28-2009 10:49 AM
    Can i put this a tranmission from a 1991 Auto 300e into my 1991 Auto 190e?? Jumanji99 W201 190-Class 1 10-24-2008 01:42 PM
    How do I add freon to a 1991 560SEL? Keith Lucy W126 S,SE,SEC,SEL,SD,SDL Class 7 08-22-2002 03:32 PM
