Is this the transmission Vacuum modulator and if so.. - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 10-23-2011, 01:05 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Originally Posted by ladd220 View Post
Does anyone have an answer for this then?
I answered it a few posts up. You're welcome.
flyboyike is offline
post #12 of 13 (permalink) Old 10-23-2011, 01:13 PM
ladd220's Avatar
Date registered: Jan 2011
Vehicle: w124 coupe E220
Thanks for that. I tried to pry mine off with a screw driver some time ago, but it looked like it was about to break, so I stopped...!
After having read the posts I think I'll go for the replacement option as I too have a jerky gear change from 1st to second gear even though I changes the atf and filter.
Thanks again.
ladd220 is offline
post #13 of 13 (permalink) Old 10-24-2011, 05:08 AM
Date registered: Jun 2011
yeah, we accidentaly pulled our pipe off when we did the head, cos we had to lift the manifold too and it just popped the pipe off from the gearbox
LUCIFER-V12 is offline
    Automatic Transmission Vacuum Modulator Adjusting??? 85300CD W123 E,CE,D,CD,TD,TE Class 5 05-13-2012 11:32 AM
    Solenoid for Transmission Vacuum Modulator? 93190E W201 190-Class 5 04-12-2011 03:03 PM
    Transmission vacuum modulator pin Bhaecker W123 E,CE,D,CD,TD,TE Class 2 12-17-2008 10:28 AM
    Transmission Vacuum Modulator Adj. dbmoylan W140 S-Class 5 06-29-2008 11:10 PM
    Transmission vacuum pressure modulator adjustment conbobway W124 E,CE,D,TD Class 9 12-02-2007 05:11 AM
