new benz owner :) - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-14-2011, 09:34 AM Thread Starter
Date registered: Oct 2011
Vehicle: 85 300D
new benz owner :)
Hello all!
I joined this site to help with any questions I may have in the future with my "new" 85 300D.
Eventually I'd like to either brew my own biodiesel or add a tank to run on wvo, time will tell. Until then I've only put B20 in the tank and she runs great.
I am having issues with the aux/ac fan. I just replaced the relay, no voltage at the fan, tried jumpering the wires(as suggested in a thread here) to run the fan all the time regardless of temp settings, still no voltage at the fan. Took fan apart and cleaned it all up, connected to 12v supply and nearly took a finger of, the fan spins wicked fast! I'm about to just wire the fan with its own fuse to a switch...
That is all.
jonan is offline
post #2 of 3 (permalink) Old 10-15-2011, 10:03 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
post #3 of 3 (permalink) Old 10-15-2011, 10:41 AM Thread Starter
Vehicle: 85 300D
I am not new to forums. I understand what the intro section is for.
I didnt ask for help, I simply stated where I was at with my MB
I will be filling out the profile info soon.
Thanks for the welcome! Im sure I'll be here for quite a while
jonan is offline
    New Benz owner/Master Benz tech. MBENZTECH General Mercedes-Benz 6 01-09-2012 09:53 AM
    New S500 owner with FAQ, 4th Benz owner rval_1999 W220 S-Class 3 09-15-2011 04:52 PM
    New Benz owner needs help laurajtaz W203 C-Class 7 05-14-2008 09:39 AM
    New Benz owner...need a little help pls... DMC_S2000 W123 E,CE,D,CD,TD,TE Class 9 01-27-2008 07:40 PM
    New Benz Owner! azzman W202 C-Class 2 11-01-2007 11:07 PM
