Throttle Body for 1988 300CE - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-12-2011, 07:06 PM Thread Starter
Date registered: Oct 2011
I believe the throttle body in my 300CE is about to go out, if it hasn't already, because the car has been idling really high lately. Anyway, I was wondering would a throttle body from a 300D (Diesel) work as a good replacement? Also, I have yet to try some injector cleaner. Does anyone think this would be worth a try, especially before I go out and get a new throttle body?
Benz_300CE is offline
post #2 of 2 (permalink) Old 10-13-2011, 05:23 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
I rather doubt that your high idle condition is caused by a bad throttle body, not least because these cars don't have a throttle body in the sense that you mean, rather, the throttle plate is in the intake plenum assembly and pretty much doesn't fail. That's not to say you shouldn't clean it thoroughly every once in a while. The diesels use a completely different intake, so no, that won't help you either. I would say it's more likely your idle control valve is stuck wide open, either due to failure or to grime.
Your Parts Search Returned 1 Part(s)
flyboyike is offline
    95' C280 Throttle Actuator/Throttle Body removal? FRANKTHETANK W202 C-Class 5 10-19-2013 01:12 PM
    Throttle Body for 1988 300CE Benz_300CE General Mercedes-Benz 1 10-13-2011 03:00 AM
    Throttle Body for 1988 300CE Benz_300CE W124 E,CE,D,TD Class 2 10-12-2011 09:26 PM
    Will A diff from a 1993 300CE convertible fit in a 1988 300CE? SChalmers W124 E,CE,D,TD Class 41 07-04-2011 08:44 AM
    Need 1988 300CE Lower Body Moulding 1988_300CE For Sale/Wanted/Trade/Giveaway 0 10-08-2009 01:04 PM
