C230 P1420 Error + One Oxy Sensor error - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-11-2011, 06:20 PM Thread Starter
Date registered: Oct 2011
I have a 2000 C230 Kompressor which just started presenting a check engine light. A review of codes at Auto Zone showed P1420 and a code for one of the oxy sensors (sorry, hubby did not write that down).
In addition to this new check engine light issue, recently, I thought I have noticed a lack of get-up-and-go, but, I have no scientific proof of this. Also, we have been having more frequent issues with our door-mounted seat adjustment buttons. Sometimes they work, sometimes they do not - can not seem to find any pattern to this behavior.
Oxy sensors were changed about 1 1/2 yrs ago, guess could be bad again?
I have reviewed P1420 search results here and they all seem to point to resolution on SLK models, usually which also get a series of 4-5 other codes at the same time. The fix there seems to usually be the resoldering on the K40.
Does the C230 have the same K40 or do I need to look at something totally different?
Is it possible the O2 sensor could be bad again after only 18 months or so (maybe 20,000 miles of driving) or could one bad solder trigger an "extra code"?
Any opinions appreciated!
NCBenzLady is offline
    P0341 camshaft sensor -Error won't go away!! jc-place W210 E-Class 7 06-04-2011 09:39 AM
    ABS speed sensor error Sinned420 W140 S-Class 6 10-20-2010 12:13 AM
    Steering Wheel Volume ERROR ERROR ChiGuy W203 C-Class 0 03-11-2010 08:00 AM
    New Owner Rite of Passage: Error codes p1235, p1236, p1420 & p1525 slk230_itch R170 SLK-Class 7 06-01-2009 06:16 PM
    CAM Sensor Error Code? merc113 V-Class 1 06-23-2008 08:40 AM
