D Jetronic Idle Air Valve - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-11-2011, 09:15 AM Thread Starter
Date registered: Oct 2011
Trying to fix a no cold idle on a 71 W114 280CE with M110 and D Jetronic. Looking at all the great D Jetronic information on the site, the fault would appear to be with the thermal expansion activated idle aux air valve.
1. No problems starting
2. No idle when cold, but ok with throttle just a little open
3. Tick over fine one normal temp reached.
The valve when cold seems to be stuck open and supplying air around the flap valve - which is what I hough to be correct. I am expecting the valve to close when normal temp is reached so only air path is through the throttle flap valve
Checked by removing air pipe from the valve to the inlet manifold and blocking this up so there is no aux air supply, and engine idles perfectly when cold, and also compensates when auto is moved in to drive.
So should the valve be open when cold, and close when hot, and I am chasing the wrong fault?
The valve is deep down on the side of the engine under the manifold, and not easy to get to from either top or bottom, so hauling it out is going to be difficult, and I am loosing sleep trying to figure this out!
Dombert03 is offline
    Idle control valve/air slide valve question dcrews R/C107 SL/SLC Class 5 05-24-2010 01:54 AM
    Wanted - Idle Actuator (Idle Speed Control Valve) Chop 'n' Join For Sale/Wanted/Trade/Giveaway 2 03-30-2010 06:06 PM
    Video: k-jetronic adjusting warm-up valve, system & control pressure harlz W126 S,SE,SEC,SEL,SD,SDL Class 4 07-18-2009 10:49 PM
    K-Jetronic / M110 Idle issues volvo164 R/C107 SL/SLC Class 11 04-30-2009 07:26 PM
    72 280 se 4.5 d jetronic idle adjustment Blu-spot Vintage Mercedes-Benz 4 07-12-2008 01:40 PM
