battery Light - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 10-11-2011, 11:15 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
the one about pronouncing English with missing front teeth.
Kajtek1 is offline
post #12 of 19 (permalink) Old 10-11-2011, 11:49 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
I take it, yours have been gone for some time now?
flyboyike is offline
post #13 of 19 (permalink) Old 10-11-2011, 02:45 PM
Kajtek1's Avatar
shouldn't you welcome me to the club?
define gotcha - Google Search
Kajtek1 is offline
post #14 of 19 (permalink) Old 10-27-2011, 01:08 PM
Date registered: Oct 2011
Vehicle: 2000 ML430
i got the same problem except my car is a 2000 ml430 mileage is running 170xxx. battery light came on took it to the shop and it was bloew 10v so bought a new bosch battry and put it in but still the battery light is on! is it the alternator?
K.Lor is offline
post #15 of 19 (permalink) Old 10-27-2011, 01:10 PM
Vehicle: 2000 ML430
K.Lor is offline
post #16 of 19 (permalink) Old 10-27-2011, 01:23 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Most likely, that's what that warning is for.
It may also be the regulator, it comes with new brushes and is pretty easy to change, part is about $50 at the dealer.
Good luck.
Check Codes is offline
post #17 of 19 (permalink) Old 10-27-2011, 01:28 PM
Vehicle: 2000 ML430
Good luck.
but isnt the regultor install into the alternator?
K.Lor is offline
post #18 of 19 (permalink) Old 10-27-2011, 01:45 PM
Quoted: 35 Post(s)
Not exactly. It piggybacks onto it.
1. Disconnect battery.
2. Remove serpentine belt.
3. Remove alternator.
4. Unscrew regulator (2 screws?).
5. Fit new regulator using old screws.
6. Reinstall alternator.
7. Reinstall fan belt.
8. Reconnect battery.
9. Run resets (from manual).
10. Enjoy.
You will need some e-torx sockets to remove the alternator, but other than that the job is pretty simple. I think there is a basic R&R for the regulator in the W210 section help stickies, it's the same basic unit. For that matter there may be good info in the forum for your vehicle, the W163 forum.
Good luck.
post #19 of 19 (permalink) Old 10-27-2011, 01:48 PM
Vehicle: 2000 ML430
10. Enjoy.
Good luck.
thanks for the info i'll do that and see what happens
K.Lor is offline
    Battery Light On: Changed Regulator + Battery... STILL ON! sightless R170 SLK-Class 7 06-25-2011 05:51 AM
    Battery (charging) light is on with battery connected and ignition off. Koruldon W123 E,CE,D,CD,TD,TE Class 2 01-03-2011 10:07 PM
    Battery light T22TAD V-Class 2 01-20-2008 11:05 AM
    Battery Light, Brake Light, etc. VR6MAN W126 S,SE,SEC,SEL,SD,SDL Class 5 01-07-2008 03:51 AM
    Dim Battery Light ML430-OFFROAD W163 M-Class 11 04-26-2007 08:31 AM
