1982 280SE cutting out when warm - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-10-2011, 02:12 AM Thread Starter
Date registered: Sep 2011
I just bought a 1982 280SE, had a few small probs so got it cheap. Was misfiring when I first got it but did compression test and found it to be all ok, turned out to be the ignition leads replaced but put back on in wrong order.
So now it has new leads, new spark plugs and runs like a dream... Until at operating temperature. As soon as the temp gets up it will stall/cut out when stopped, it will start again but if revved up and acelerator let go it will stall again.
This is my first Mercedes so not sure if there is a common problem with these engines? (M110) Any help would be greatly appreciated.
Thanks, Ali
Ali280SE is offline
    Idle surge / hesitation / cutting out when warm! bielefeld280se W126 S,SE,SEC,SEL,SD,SDL Class 11 11-19-2012 02:02 PM
    280SE 4.5 horrible performance when warm ArcanumOne Vintage Mercedes-Benz 0 03-03-2008 07:31 PM
    72 280se 4.5 warm start problem roadrosen Vintage Mercedes-Benz 12 05-08-2007 02:10 PM
    280se euro in US 1982 taijrai W126 S,SE,SEC,SEL,SD,SDL Class 6 04-14-2005 09:03 PM
    280SE, 1982 - should I buy it? Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 2 04-01-2001 02:30 PM
