Looks good, hurts MPG's - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-08-2011, 07:20 PM Thread Starter
Elvis_Presley's Avatar
Date registered: Apr 2011
Vehicle: 2002 e320 4matic Wagon
Quoted: 39 Post(s)
1. Larger wheels (with smaller sidewalls and wider tires). Prius owners who upgrade to from 15's to 17's loose 5mpg. Why? More rolling resistance and more weight. The shorter sidewalls also give a harsher ride--they are only good for corners.
2. Grills. A modern car can cool fine without them--and they are one of the biggest sources of drag.
Anything else to add to the list?
Elvis_Presley is offline
post #2 of 5 (permalink) Old 10-11-2011, 02:06 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Sure, wings and spoilers.
BTW, the only cornering that's improved by wider tires is dry road cornering. Wider tires equal less traction always in wet or snowy conditions.
Kent Christensen
'07 GL320CDI
lkchris is offline
post #3 of 5 (permalink) Old 10-11-2011, 02:54 PM
Kajtek1's Avatar
Quoted: 1057 Post(s)
I experienced about 5% mileage drop when my fan clutch bearing froze and I drove with fan on for 1000 miles. So when you make smaller grills, you will need more fan power. That will not end with savings.
Myth Busters did some tests with one of the econobox.
The test was started at high speed and continued without changing the speed till the finish mark, so it was test for drag only.
Adding 900 lb of clay to smaller car did not change mpg at all, but making dents on the body similar to golf balls increased mpg by 11%.
Such a car covered with dents might look funny, but sure made me thinking.
Kajtek1 is online now
post #4 of 5 (permalink) Old 10-11-2011, 03:03 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Check Codes is offline
post #5 of 5 (permalink) Old 10-12-2011, 06:08 PM
Sailor94511's Avatar
Date registered: Nov 2010
Vehicle: 1992 SL 300, 1994 E320, 1999 Land Rover Dicso II
Next time there's a hail storm, pull your car OUT of the garage. ;>)
Sailor94511 is offline
    Drop in MPG's?? TheDon04 W124 E,CE,D,TD Class 0 02-09-2011 02:04 PM
    MPG'S JUST KEEP GETTING BETTER.... arceo_1 W126 S,SE,SEC,SEL,SD,SDL Class 1 10-06-2009 12:38 AM
    2007 ML CDI MPG's zak W164 M-Class 6 12-14-2008 07:08 AM
    M110 MPG's 79Mercy W126 S,SE,SEC,SEL,SD,SDL Class 4 05-21-2008 06:55 AM
    ML CDI - MPG's zak W164 M-Class 11 04-08-2008 02:09 PM
