2000 vito replacement engine problem - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-07-2011, 04:40 AM Thread Starter
Date registered: Jul 2011
Vehicle: Vito 2000 110CDi
Hi All,
Got a cdi110 that needed a replacement engine. Done. And it works... except there is a distinct lack of power to the point of having to change down to 4th when going up hill on a M'way. And when I change up gear, its like any momentum that the engine carried is lost and it has to build it revs up from scratch.
Anyway, 2 professional turbo companies have diagnosed the the turbo is ok and gets up to pressure (eventually). When I floor the throttle I get a lot of black smoke, more than you usually get from flooring a diesel.
It still sounds like a turbo fault but I cant argue with the diagnostics.
I have also changed the clocks as I have heard they could be at fault but no change.
Do my injectors need calibrating to the ECU or something? What else could the problem be?
NiceWheels is offline
post #2 of 2 (permalink) Old 10-08-2011, 04:33 AM
eric242340's Avatar
Quoted: 283 Post(s)
You would do far better asking your questions on the forum in this link;
V-Class - Benzworld.org - Mercedes-Benz Discussion Forum
eric242340 is online now
    Vito 108cdi Engine problem maybe? scouseiron69 V-Class 14 12-31-2012 03:37 PM
    vito 110cdi van year 2000 x where is the fuse for the engine cooling fan stumpy231 V-Class 2 04-25-2011 06:56 AM
    problem wobbly handling vito 110cdi 2000 reg mick2a V-Class 7 10-20-2009 12:01 PM
    problem with codiren vito cdi 2000 josip77 V-Class 0 11-05-2005 11:20 AM
    Vito 108D 1999 Engine Problem Steve Mow V-Class 3 01-12-2005 09:43 AM
