2000 CLK 230 Reversing light malfunction - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-07-2011, 01:29 AM Thread Starter
Date registered: Oct 2011
I have a malfunction warning which I believe is a reversing light problem as they do not appear to be working, please are there any suggestions as to a course of action.
Namretaw is offline
post #2 of 3 (permalink) Old 10-07-2011, 01:38 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Check the fuse, then the bulbs.
flyboyike is offline
post #3 of 3 (permalink) Old 10-08-2011, 04:42 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 385 Post(s)
The W208 uses two designs of auto gear shift mechanism. Before 30/06/99, the Floor shift is fitted. After 01/07/99 the Electronic Selector Module (ESM) (N15/5) was introduced.
If you have a Floor shift, your problem is possibly a faulty back-up lamp switch (S16/10s1). Do you see the R illuminated by the shift lever when in reverse?
The switch is located on the side of the floor shift assembly, which has to be removed to get access to the switch. The switch is sited immediately beneath the gear range recognition switch (S16/10) and both switches have connectors/cables that have to be removed to reach the switches.
If you have the later Electronic Selector Module (N15/5), the reverse signal is derived electronically with no individual switch. The decoded signal shift lever position can be checked at a socket with the connector removed.
keyhole is online now
    Malfunction : Tail Light - Rear Fog Light S430 2004 4Matic Pratt Montreal W220 S-Class 1 03-20-2011 07:01 AM
    No Reversing Lights or Reversing Aid Bars Judas W140 S-Class 4 10-16-2010 09:06 AM
    Car wont start, instrument cluster down,reversing light fuse melted Tina1 W202 C-Class 0 08-17-2010 02:20 AM
    Reversing light adjustment scanner1 V-Class 0 12-08-2008 08:54 AM
    w111 reversing light Montclair Benz Vintage Mercedes-Benz 0 09-16-2008 09:39 AM
