Climate control problem - Diag. KLA A ERROR 1000 - anyone have info on this? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-04-2011, 07:27 AM Thread Starter
Date registered: May 2010
Vehicle: 2005 CL55 AMG
I have a 2005 CL55 AMG. The climate control blows cold when in LO and hot any other temperature setting. As the AC works on LO, I know the compressor is working and the fan etc., but not at any other temperature. I opened up the dash took out the climate control unit and looked at it to see if something fried and cleaned off the very dirty temperature sensor. Put it all back together an made no difference.
I did the self-test by putting climate on Lo left side Hi right side and held down the filter and REST buttons for 5 seconds. It self tested and gave me Diag. KLA A ERROR 1000
Anyone have any info or experience with this. I don't really want to go to the stealership and pay a $150 diagnosis fee to find out its a $25 sensor I could change myself. Any help is appreciated. Thanks.
evolefil is offline
post #2 of 4 (permalink) Old 02-12-2013, 07:56 PM
reinaldtreska's Avatar
Date registered: Apr 2008
Vehicle: 2001 S430 1998 S320 2006 CLS 500 1997 E320 (sold) 1998 S600 (sold) 1995 S420(sold) 1995 S500 (sold)
I do have the same error
I do have the same error code .I see that your post is old so hopefully you got it fixed already.Would you mind telling me what it was ? Thnx in advance
Ray
reinaldtreska is offline
post #3 of 4 (permalink) Old 08-24-2013, 10:27 PM
Date registered: Mar 2012
Vehicle: 02 CL55 AMG Clone, 99 Ford E150, 16 ft boat
also wondering about the same code on my 02 CL
my symptoms are warm a/c on passenger side and not very cold a/c on driver side no matter what temp...i've noticed the a/c seems slightly colder whne i'm under shade so myabe its just the sun sensor?
i can clear the code and it won't come back for a couple weeks at a time...i checked my freon and the gauge said it was in a dangerously high level so i don't know what to think
this only happened after i did an engine/tranny swap though...
-02 CL500 to 02 CL55 ///AMG engine/tranny swap, coilover suspension, Lorinser fenders and trunk lip, 2 12" kicker CVR's, 20 inch Giovanna kilis in flat black
check out my band!
ctravis595 is offline
post #4 of 4 (permalink) Old 12-13-2014, 08:41 AM
Date registered: Jul 2011
Vehicle: 2000 S500
I have the same error code did you figure out the issue diag. kla v error 1000?????
DaveS320 is offline
    Heat Stuck on, Climate Control Panel/Climate Control Servo Problem? 123Doug W123 E,CE,D,CD,TD,TE Class 25 05-07-2016 12:40 AM
    Climate control error codes celm W210 E-Class 3 02-18-2009 01:30 PM
    Climate Control Error code: 61234 ideas? gcavy1 W210 E-Class 5 01-01-2009 09:02 AM
    Climate Control Unit Diag. Code ChicagoMB W202 C-Class 1 08-30-2008 11:42 AM
    Climate Control Error Code Eb1422 odario W210 E-Class 18 07-28-2008 08:51 AM
