2005 s600 climate control - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-03-2011, 09:37 PM Thread Starter
Date registered: Oct 2011
Vehicle: 2006 s600
I am new to the forum. I apologize if this thread has been posted. I did a search and didn't find anything. One out of the four zones in climate control system only blows warm air. Three out of four zones works just fine. Any ideas? thank you.
bigsece is offline
post #2 of 3 (permalink) Old 10-06-2011, 11:55 AM
Im having the same issue with a S550.
one vent is cool air other three will do heat or a/c intermittently.
SwiftAutoworks is offline
post #3 of 3 (permalink) Old 10-06-2011, 12:07 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
These two cars are quite different. The W220 issue typically is one of the valves, the 4 zone system should have two sets of duo-valves, check the one that appears to cause problems.
The 221 could be one of the air flow control flaps although this does not seem to be a typical issue.
The car specific forums would probably give better guidance for both.
Diesel Benz is online now
    97 S600 climate control question ok_simpson W140 S-Class 8 08-22-2010 08:28 PM
    Removal center console wood lower upper climate control unit off S600 jorghenry W140 S-Class 7 04-18-2007 02:34 PM
    Climate control issue 2005 c230 nyclad W203 C-Class 10 02-11-2007 08:53 AM
    S600 Coupe '95 Climate Control Unit leosoft W140 S-Class 2 06-29-2006 04:18 AM
    2005 radio & digital climate control Harrijunsun W203 C-Class 1 09-22-2005 10:56 PM
