ABC Issues! Please Help! - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-03-2011, 11:47 AM Thread Starter
Date registered: Oct 2011
I have a 2001 CL600. Have owned the car for one month bought with 74500 miles. Drove it for one week after seeing the red warning "ABC WARNING, DRIVE CAREFULLY". Shortly after this the rear dropped at 25 MPH taking paint off wheel wells. Flat bead to MB dealer for diagnostics. Was told the tandum pump was leaking and that would fix the issue.
One week later picked the car up. Drove 50 miles and same issue occured, only front and rear this time. Took back to MB dealer for them to tell me a valve gave out due to proper pressure and weak valve. Had them fix that and 5 days later, pick car up and drove one day and same issues happening. Only at low speeds.
Dealer came with flat bed back to MB shop. They checked it out and says all systems fine, no leaks, only code is "car to low". They dont know what to do now.
Any suggestions? Please!!
Mulop is offline
post #2 of 5 (permalink) Old 10-03-2011, 01:04 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Have it towed to a different dealer that knows what they're doing.
flyboyike is offline
post #3 of 5 (permalink) Old 10-03-2011, 01:16 PM Thread Starter
They told me it is ABC control modual. Said the car dosnt know what possition to be in with faulty modual.
Mulop is offline
post #4 of 5 (permalink) Old 10-04-2011, 05:51 PM
Dylan's Avatar
Date registered: Sep 2004
Send a message via Yahoo to Dylan
X2 on taking it to another shop.
with the star tool, they can run several test on the system and activate the abc struts. It will also give realtime data on the system. I would assume a faulty module would show on the star tool very easily.
Unless this is all under warranty then I would let them keep swapping everything they want under the warranty so you have a new system with they get finished. I would also demand a loaner car.
Dylan is offline
post #5 of 5 (permalink) Old 10-04-2011, 07:06 PM
Kajtek1's Avatar
Vehicle: E320/E250 Bluetec R129 SL500 - $1300 car ........ Ford F350 6.7l
Quoted: 1346 Post(s)
Warranty on 2001 model?
I'd say the dealer is milking the customer, or is learning how to fix the car on customer wallet. Changing the shop at this time might bring some issues, but call MBUSA and ask for assistance.
Kajtek1 is online now
Idle issues intermittenly and timing issues guinter810 W124 E,CE,D,TD Class 3 10-25-2010 12:28 PM
240D Starter issues or wiring issues LovingTheInsectorcist W123 E,CE,D,CD,TD,TE Class 8 07-09-2009 05:11 AM
COMMAND COMMUNICATION ISSUES & GATEWAY 500 WARRANTY ISSUES POURCTYSBKON Audio & Telematics Forum 2 12-26-2008 02:40 AM
S600 low battery issues (Limp home, Idle issues, P1581 DTC and ESP lamp)... bdkorn W140 S-Class 8 04-07-2008 09:24 PM
Braking/suspension issues? Electical issues in my 2001 C-240 wilhasl W203 C-Class 4 09-15-2005 05:11 PM
