1989 Mercedes 300CE shifting/accelerating problems - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-28-2011, 09:17 PM Thread Starter
Date registered: Sep 2011
Post 1989 Mercedes 300CE shifting/accelerating problems
Over the last few years i have had a problem with my 300CE that for the life of me i haven't been able to figure out the cause.
The problem is that when I'm accelerating quickly and my car reaches 4000RPM's it will start violently shaking back, and forth it will not allow me to shift until i release the gas. Basically i need to keep it bellow 4k RPM's or i feel like the car is going to pull itself apart.
My car shifts fine if i don't floor it to the ground(also the only time it gets to 4k rpm) but i still would like to figure out whats causing the problem so i can fix it. I have replaced the fuel pumps, transmission fluid is fine, along with i believe the transmission. Any help is appreciated thanks so much in advance.
MrAlvi is offline
post #2 of 5 (permalink) Old 09-29-2011, 03:12 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
flyboyike is offline
post #3 of 5 (permalink) Old 09-29-2011, 03:43 AM
re
Under the car in the back. There will be a black cover over it and the fuel pump.
john smith 012 is offline
post #4 of 5 (permalink) Old 09-29-2011, 07:43 AM Thread Starter
Where can i find that valve and how will i know if its bad thanks so much for the reply
MrAlvi is offline
post #5 of 5 (permalink) Old 09-29-2011, 07:58 AM
flyboyike's Avatar
Quoted: 69 Post(s)
Left side of the transmission. The symptoms point to either it being faulty or the vacuum line going to it being damaged.
MB 300CE 1989 Starting problems stone46 General Mercedes-Benz 1 09-02-2011 06:39 PM
1989 Mercedes 300CE Coupe *1-owner* 69k miles(!) - $5995 KarlC W124 E,CE,D,TD Class 11 12-27-2008 05:50 AM
Common Problems to look for in a Mercedes 300CE ryan206 W124 E,CE,D,TD Class 8 04-22-2008 12:24 PM
92 300CE stalls when accelerating wYshbrYnger W124 E,CE,D,TD Class 7 10-08-2007 12:48 PM
Shifting on a 1992 Mercedes 300CE Cheeseman W124 E,CE,D,TD Class 2 09-06-2006 09:12 AM
