Coolant drainage in 420 SEL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-28-2011, 03:38 PM Thread Starter
Date registered: Sep 2011
Angry Coolant drainage in 420 SEL
Hi All: My Benz is a 21 year old 420 SEL with 128,000 mi on it which I bought new. Love this car, but with age comes increasing maintenance costs, so I am trying to learn to do whatever I can to save $, currently I need help in 2 areas:
1. Where can I find the drain plug for changing the coolant?
2. Car doesn't track too well and bumps in road transmit shock into steering wheel. Original 4 shock absorbers replace at 75,000 mi. I have had 3 different recomendations for repair:
a. repalce leaking steering gear box, new tie rods, steering damper and new front shocks
b. replace leaking steering gear box and the linkage that is immediately attached to it and replace ball joints (rubber caps torn)
c. ball joints are OK despite torn rubber caps, tie rods fine, leaking steering gear box still is working fine, but need to replace (?rebuild) idler arm, bushings in R and L brake support arms, and could probably use new shocks since the current Bilsteins are leaking a little. Any advice?
Gerald Cole is offline
post #2 of 2 (permalink) Old 09-28-2011, 05:58 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is online now
    01 water drainage issue DeutschMotorCar W220 S-Class 6 10-10-2011 07:47 AM
    Strange Battery Drainage Sunray C208/A208 CLK-Class 6 01-13-2011 12:38 AM
    battery drainage Joshua Lomax Vintage Mercedes-Benz 5 12-27-2009 08:53 PM
    Rear Drainage. Where From? Tubbypoo W201 190-Class 2 06-09-2009 12:12 PM
    Fender Rot - Drainage Unimog 10 04-15-2008 09:27 AM
