HELP!!?? 1993 300E - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-27-2011, 07:25 PM Thread Starter
Date registered: May 2011
Vehicle: 1993 300E 2.8
HELP!!?? 1993 300E
Hi all,
I have a 1993 300E 2.8. This afternoon I shut it off and the key turned a little past the "off" position to the left of the dot. They key would not turn after that and was very hard to get out. The lock cylinder is still in that position and a locksmith could not get it back. As a result, I had it towed home. Does anyone have any suggestion of how to fix it? Or should I just break the lock cylinder? If so, how do I do that? Thank you for everyone's time here.
mtobey is offline
post #2 of 2 (permalink) Old 09-27-2011, 07:30 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
there are lot of topics about ignition tumbler replacement and they seems to the same problem regardless the model. You will find them by forum search.
Mercedes is having ingenious steering wheel blockade that with lock tampering goes into permanent mode, so this is not a job for DIY unless you are ready to cut off the blockade and drive without it.
Take the car to the dealer and mortgage your house.
welcome to the forum
Kajtek1 is offline
    1993 300E 2.8 njb8199 W124 E,CE,D,TD Class 10 08-29-2010 09:27 PM
    Looking at 1993 300e latief W124 E,CE,D,TD Class 33 07-21-2009 11:19 PM
    1992 300E transmission in a 1993 300E 2.8 M104 engine? abiez W124 E,CE,D,TD Class 2 03-17-2009 11:17 AM
    1993 300E ifrad W124 E,CE,D,TD Class 2 07-26-2005 06:43 AM
    1993 300E osdesierto W124 E,CE,D,TD Class 1 11-26-2004 06:57 PM
