'95 300 Diesel - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 09-27-2011, 01:36 PM Thread Starter
Date registered: Sep 2008
'95 300 Diesel
i've been shopping for '95 300 diesels, and have been told to determine whether a) wiring harness and b) a/c evaporator have been replaced. a dealer suggests that this has been done for all of these vehicles out there.
does this sound correct?
thanks
dayradebaugh is offline
post #2 of 9 (permalink) Old 09-27-2011, 02:09 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
thanks
I would say most of the harnesses have, in fact, been replaced by now, at least on cars that are still running. I wouldn't be quite as certain about the evaporator, but at least the car will run fine with a leaky evaporator as opposed to a bad harness.
flyboyike is offline
post #3 of 9 (permalink) Old 09-27-2011, 04:15 PM Thread Starter
thanks very much. by the way, i just bought a '78 300d w/81K on the clock. it's not turbo charged, and runs fine. is there any way to tweak a bit more power out of these things, such as mods to the pump? it's done in the trucking business all the time.
post #4 of 9 (permalink) Old 09-27-2011, 04:58 PM
flyboyike's Avatar
Quoted: 69 Post(s)
It would be easier to just transplant a turbo engine.
post #5 of 9 (permalink) Old 09-27-2011, 07:15 PM
Kajtek1's Avatar
Quoted: 1198 Post(s)
the cheapest is to sell this car and get one with turbo. That is what I did.
wire harness on 95 300 diesel? I assume this is the same engine I had in 97 300d?
No spark plugs, mechanical injectors, no camshaft sensor. I wonder what wire harness we are talking about here?
Evaporators on those cars do break down, but not more often than on other cars.
Kajtek1 is offline
post #6 of 9 (permalink) Old 09-27-2011, 08:23 PM
Date registered: Jul 2004
Quoted: 306 Post(s)
There is an upper engine harness with about 20 end points, and it is prone to failure. If you can a find a part tag look for the FD/fabrication date to see if it is original.
deanyel is offline
post #7 of 9 (permalink) Old 09-28-2011, 08:03 AM Thread Starter
thanks very much. i had assumed that the engine was designed to run that way, and there wasn't much you could do about it, except keep your foot on the floor. that said, it runs fine, and should last forever with care. i got spoiled by my previous turbo.
post #8 of 9 (permalink) Old 09-28-2011, 10:27 AM
Kajtek1's Avatar
I drove the 134 hp non turbo and 134 hp is 134hp. Comparing to cars with 75 or even 21 hp I used to drive it wasn't bad, but the power curve was additional issue. The engine was reaching peak hp close to 5000 rpm redline, so if you wanted it to perform, you had to hear the noise. Almost the same engine with turbo gives you nice kick just above 2000 rpm
Kajtek1 is offline
post #9 of 9 (permalink) Old 09-28-2011, 12:06 PM Thread Starter
i notice the noise from it, but that's just part of the package, i guess. you turn up the radio.
    OM606 Turbo Diesel - Same Story as Oldsmobile Diesel V8? MercedesFan1981 General Mercedes-Benz 4 08-22-2011 10:35 AM
    FOR SALE: Brabus PowerXtra diesel box for I6 turbo diesel engine. mescaline W220 S-Class 3 03-17-2009 02:18 PM
    Turbo Diesel vs Super Diesel . . . what's the difference? bdonkersgoed W124 E,CE,D,TD Class 19 01-27-2008 10:13 PM
    1985 300 D Turbo Diesel Mercedes WVO Bio Diesel - $4000 Kalifornia W123 E,CE,D,CD,TD,TE Class 2 01-08-2007 01:45 PM
    Can't find the diesel G you can afford.....check out this diesel offroader mserpe G-Class 2 12-05-2002 10:12 PM
