snedw - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-21-2011, 01:56 PM Thread Starter
Date registered: Oct 2009
Vehicle: ml 320
Unhappy Stuck in 1st gear
My 2000 ml320 is stuck in 1st gear.I just replaced the battery. Could that have something to do with problem?
snedw is offline
post #2 of 2 (permalink) Old 09-21-2011, 07:11 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Your car is in limp mode and will need the fault codes read out with diagnostic equipment, possible low voltage codes, or you could disconnect the negative side of the battery for 10 minutes and then try again.
eric242340 is offline
