S500 2002 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-18-2011, 10:34 AM Thread Starter
Date registered: Sep 2011
S500 2002
I have a 02 S500, check engine light on code PO705 conductor plate. The trans does not know what gears its in sometime dash light (gear light). Had conductor plate and fluid change. The problems still there. I have to turn off car to reset and than it works sometime. need help
d -s500 is offline
post #2 of 2 (permalink) Old 09-19-2011, 05:03 AM
eric242340's Avatar
Quoted: 300 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Pull the transmission control unit out and open it, check for transmission fluid inside.
Regards
ERIC.
eric242340 is offline
    CLS vs. 2002 S500 smastin C219 CLS-Class 2 08-05-2011 09:36 AM
    Please Help!!! Question about 2002 S500 MRakkar916 W220 S-Class 6 02-03-2010 10:44 AM
    2002 s500 PLUMERDAN General Mercedes-Benz 1 08-09-2009 10:15 PM
    2002 S500 w/ Sport Pkg. RadarMon General Mercedes-Benz 1 06-20-2009 09:36 PM
    AMG's on a 2002 S500 froggyg The Discount Tire Direct Tire, Wheel, Brake & Suspension 6 06-10-2009 02:07 AM
