1998 E320 Starter? Help ! - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-14-2011, 06:47 PM Thread Starter
Date registered: Nov 2009
Vehicle: 2000 S430
Unhappy 1998 E320 Starter? Help !
Hi again. My 98 E320 all of a sudden will not start. Clean Battery terminals, good battery, even tried jumping it, nothing. Never had any indication of faulty starter before. Started fine the night before, today, nuttin. I get full power to the dash, all components work, starter is not clicking, just a humming from that general area in engine compartment. I have 184k miles. Hoping for a simple fix other than bad starter. Any ideas? Thank you.,
NOTE: Check engine light came on last week, throwing a P0140 code, however that comes on a lot.
petkennel is offline
post #2 of 6 (permalink) Old 09-14-2011, 07:40 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Humming you say. Loud?
flyboyike is offline
post #3 of 6 (permalink) Old 09-14-2011, 07:42 PM Thread Starter
Vehicle: 2000 S430
humming
Not humming loudly at all. In fact, I could hardly hear it, ,might not even be the starter.
post #4 of 6 (permalink) Old 09-14-2011, 09:44 PM
Kajtek1's Avatar
Quoted: 1289 Post(s)
You do know that this always happens when the battery is low?
Did you test your battery?
Kajtek1 is online now
post #5 of 6 (permalink) Old 09-14-2011, 10:58 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
I'm grinning about two things.
First, how spoiled we have become. I can remember that if you got 80-100k out of a starter that was great.
And I'm bemused by the irony of having a *very* complex set of interrelated systems and hoping that the "quick fix" isn't just replacing a starter with 184k on it. To me that would be preferable to nearly any of the other alternatives.
OP: Please click user CP and edit details so you can add your vehicle and location to your profile. It's often useful information when you're seeking assistance.
Were I you, I'd pull the belly pan and check to be sure the ground strap was in good working, with clean, tight connections.
If that was good, I'd disconnect the battery, pull the starter, and test it.
Also, when you need help on a specific model, it's often far more useful to post in the forum that is specific to your car. This general forum is just that, topics of general application to MBs broadly. In your case that would be the W210 forum.
In any event, I would check the ground and starter and go from there.
Good luck.
Check Codes is offline
post #6 of 6 (permalink) Old 09-15-2011, 03:54 AM Thread Starter
Vehicle: 2000 S430
Battery
I did not test the Battery but I did try and jump start it with another car with no luck.
I did post on the W210 forum after realizing general was not the place. Thank you again.
ML 320 1998 starter gets stuck and car wont fire up motoadve W163 M-Class 24 12-29-2016 04:32 PM
Can I Install A Remote Starter On 1998 E320?? SomeGuy07 General Mercedes-Benz 9 09-10-2016 10:39 PM
Where is the starter on a 1998 ML320? crdnlsgrl W163 M-Class 5 10-22-2015 11:40 AM
1998 E430 starter removal, Please help!!! 98e430sport W210 E-Class 7 12-28-2014 08:55 AM
Replace the starter (or just solonoid) change on 1998 E-320 Paul Mellerowicz W210 E-Class 2 09-02-2007 05:04 AM
