Changing low beam bulb on '04 CLK 240 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-13-2011, 12:46 PM Thread Starter
Date registered: Sep 2011
Smile Changing low beam bulb on '04 CLK 240
Drivers side, you have a cover with a lift clip about 1 o-clock. Lift the clip and the cover will swing out from the bottom slots and you remove it. Remove the wire plug from the bulb, press the retaining spring clip, that is pressing on the bulb base, down and to the left to remove the spring from the dual hanger slots. The bulb will then come out. To replace, make sure that the small tip of the bulb base is at the top and placed in the top slot. Press spring clips down and back into the hanger slots and replace the outer cover.
Wilibill is offline
post #2 of 2 (permalink) Old 09-14-2011, 05:12 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
flyboyike is offline
    How to Replace Low Beam Bulb? geli7 General Mercedes-Benz 7 01-22-2011 03:00 PM
    low beam bulb sergiu W163 M-Class 10 05-18-2010 04:06 PM
    Low Beam Bulb Fuse anant0087 W204 C-Class 2 10-22-2009 10:00 PM
    Changing the fog beam bulb pdiddy26 W211 E-Class 6 01-02-2008 10:14 PM
    Low beam bulb replacement? BigTime W211 E-Class 6 06-14-2006 10:29 AM
