91 190e 2.6. Stall when i turn right. not left - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-08-2011, 06:41 PM Thread Starter
Date registered: Sep 2011
Vehicle: 91 190e 2.6. gold
Post 91 190e 2.6. Stall when i turn right. not left
After goin threw hell, and fine tuning this puzzle of my life, my new issue is that when i turn right she stalls out, then either dies completly or hangs on. happened a few times on only one freeway off loop at the stop sign of the ramp. then thought it was to rich, adjusted air mixture slightly, didnt happen again...till yesturday(two months later), only not at the off ramp but at any turn i made. i checked my vacum lines, and coil(2 years old), looked for anything unuasal. OPR fuse is not burnt. and i shook the fuel pump relay as it ran to see if the connection was bad.i have recently replaced my fuel pump(which buzzes a lil while idleing) way before any of this. I just test drove it to find out 360 degree left turns are fine, but any slight right turns are stalling....as my old french mercedes mechanic would say "what the F man"...( he recently passed away)..
J. rawton is offline
post #2 of 3 (permalink) Old 09-09-2011, 05:02 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 16 Post(s)
Test the wiring at the fuel pump via wiggling while a meter is hooked up to it for an interruption in voltage.
Also, it may be possible you received a faulty fuel pump, in which the roller vane inside is losing connection internally, causing the fuel pump to shut off from the inertia in right turns, i.e., the internals are shifting.
Nutz 4 Benz is offline
post #3 of 3 (permalink) Old 09-09-2011, 05:10 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Hmmmm....a left-leaning Mercedes.
flyboyike is offline
    mercedes 190e intermittent stall gowirelessmwebb W201 190-Class 10 03-15-2011 06:39 AM
    Left turn More than Right.. javadude W126 S,SE,SEC,SEL,SD,SDL Class 8 05-01-2010 06:55 PM
    190E 2.3 stall problems - found loose tube - need suggestions Q-BiC W201 190-Class 23 09-17-2006 11:26 PM
    190E 2.3 stall problem: an odyssey psemerson W201 190-Class 3 06-19-2006 11:56 AM
    88 190E 2.3 - Start it hot, stall it out psemerson W201 190-Class 9 02-28-2006 12:28 PM
