Front Brake Pads - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-06-2011, 06:06 AM Thread Starter
Date registered: Feb 2005
Vehicle: 2011 E-350 Bluetec & 1991 300 SE
Front Brake Pads
How difficult to change the front brake pads on my 1991 300SE?
mvbiondi is offline
post #2 of 5 (permalink) Old 09-06-2011, 07:03 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 341 Post(s)
From my WIS - it looks quite straightforward if you can manage to jack the car and remove the front wheels.
Please confirm that you are talking about the brakes on a fixed caliper on front axle, with the pad wear sensor feature. (earlier model were on a floating caliper)
If you clarify and re-post this question in the W126 forum (where the owners of similar models hang out) I will post images of the procedure from the WIS with all details.
keyhole is offline
post #3 of 5 (permalink) Old 09-06-2011, 07:35 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
If you have a floor jack and jackstands, I'd say an hour's job.
If you have to jack up each wheel individually, add another 30 minutes.
flyboyike is offline
post #4 of 5 (permalink) Old 09-06-2011, 08:51 AM
Kajtek1's Avatar
Vehicle: w211 E320 wagon 4M / Bluetec / Ford SD. Seeking affordable diesel pushmower
Quoted: 1044 Post(s)
I would tend to say "if you have to ask, better take it to professional"
Brake pads are not hard to replace, but if you mess something up, the consequences can be tragic.
I always encourage DIY, but only if you have somebody with the experience to inspect the job at the end.
Kajtek1 is offline
post #5 of 5 (permalink) Old 09-06-2011, 10:56 AM
keyhole's Avatar
Quoted: 341 Post(s)
Take a look at post #27 on the following thread on the W126 stickies here:
The post covers your topic very well - except I would have pressed brake fluid back into the reservoir during the pad insertion, rather than draining it at the local bleed nipple. He forgot to mention finally topping up the reservoir, also.
keyhole is offline
    Is it okay to change front brake pads and then change rear pads about a month later? jay (new jersey) R170 SLK-Class 5 07-17-2012 12:12 AM
    front front brake pads...anyone else have this problem? benztech123 W123 E,CE,D,CD,TD,TE Class 11 05-03-2010 08:02 AM
    Front Brake Pads jetmech0 W126 S,SE,SEC,SEL,SD,SDL Class 2 04-23-2010 07:31 PM
    Brake HELP What's the best thread for DIY front brake pads? victorcaloca W203 C-Class 27 05-16-2009 02:48 PM
    w123 rear brake pads=VW beetle front pads? eurobluebenz W123 E,CE,D,CD,TD,TE Class 9 05-09-2006 06:28 PM
