Soft top control module 98 SL500 - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-02-2011, 12:45 PM Thread Starter
Date registered: Jan 2010
Vehicle: 1998 SL 500 R129
I'll start with yet another bad experience with the dealer. After removing the hard top for the summer, I found that the soft top only went half way up. I was able to get the top back down but then the roll bar locked up in the up position and the top would no longer work. The roll bar switch also did nothing although I could see a faint red light behind the switch. The blinking red switch to contol the top stayed on. From reading the forum, I was optimistic that it was a simple mater of having the dealer clear the fault codes and I would be on my way. Took it to the dealer where they said this was not the problem and after an hour of labor wanted to keep it longer. I could not leave it with them. A few weeks later I took it back for further diagnostics. After another 3 hours of labor, they informed me I needed a new soft top controller at a price of $2900. No thank you! After I paid them a total of close to $500 for this news, I brought it home and removed the controller and sent to BBA Remanufacturing. I paid them to tell me there was nothing wrong with the after shipping $80. They did tell me that a fault code came up (Hydraulic pump motor overheat) and they cleared it. Dealer should have seen this! So this is where I am at this point. Ready to blast the dealer because I'll never go back anyway. I suppose the next step for me will be to replace the relay located at the pump (the cheaper option at this point). If this doesn't solve the problem, I guess I will need to either replace the pump or send it for repair. Any help on this matter would be greatly appreciated.
Last edited by restless2go; 09-03-2011 at 07:50 AM. Reason: move to appropriate sub forum
restless2go is offline
post #2 of 2 (permalink) Old 09-02-2011, 07:15 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    RST Roadster Soft Top Control Module Repair - BBA Reman carloz R129 SL-Class 45 03-13-2013 02:50 PM
    Soft top control module L1V3zaj R129 SL-Class 13 09-04-2011 08:02 AM
    Mercedes Benz SL500 SL320 129 soft top control module in Atlanta khmlucas For Sale/Wanted/Trade/Giveaway 0 07-09-2009 07:05 PM
    Soft top control module on ebay (3 plug module) StuartKnight R129 SL-Class 0 11-13-2007 06:14 AM
    SL500 Soft Top Control Module jstalker BenzWorld Help 0 05-30-2007 05:29 AM
