99 ML430 multiple codes after driving thru water during hurrican irene HELP!!!! - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 09-06-2011, 12:35 PM Thread Starter
vansolone's Avatar
Date registered: Aug 2011
Vehicle: 1999 Mercedes ML430
Thank you for the link. The water that the car went through was not too deep where water went into the car or covered the engine. I went thru the same puddle with my honda odyssey and no issues.
My girlfriend was behind me in the Mercedes when this happened and it drove home fine. It was the next day when the troubles started.
Based on the link, I had the 4 coils changed already: should I change the MAF? I checked the air filter and had no signs of water.
vansolone is offline
post #12 of 13 (permalink) Old 09-06-2011, 02:27 PM Thread Starter
vansolone's Avatar
Update:
I spoke to a couple of people locally plus my mechanic. He did disconnect the CAT and tried to start the car and same issues were present.
He mentioned during his testing, that the one side of the engine is not getting spark. Could this be the Crankshaft Position Sensor? It is in the right area where the car would have went thru the water.
I am just reaching here and just looking for that needle in the hay stack so I don't have to go and spend mucho $$$$$$$$$$$$$$ to fix this issue.
Thanks.
post #13 of 13 (permalink) Old 09-06-2011, 04:08 PM
mbvis's Avatar
Date registered: Jan 2010
Vehicle: 99 E430, 01 E430 Sport, 00 SL500
Quoted: 2 Post(s)
It does not hurt to remove a few spark plugs to see if any water actually got in. That's what the OP in "engine-submerged-water" post found out himself.
You can remove the plugs, too, without a mechanic. Make a spark plug boot tool.
mbvis is offline
multiple stereo issues, '99 ML430 Maytag W163 M-Class 5 07-09-2011 08:12 AM
04 C320 MULTIPLE ENGINE CODES HELP PREZAUTO1 General Mercedes-Benz 2 03-17-2011 01:03 PM
Help, Multiple Codes maddog096 R170 SLK-Class 3 11-17-2010 06:35 PM
Multiple Codes Nighthawk1961 R129 SL-Class 5 03-08-2010 12:09 PM
Need Help w/Multiple codes on my 97 E320 jlealmbz W210 E-Class 3 04-22-2008 08:17 PM
