W124 Popped a sudden water leak, but engine wasn't overheating! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-29-2011, 06:35 AM Thread Starter
Date registered: Aug 2011
Vehicle: W124 (E280) model 1994
Exclamation W124 Popped a sudden water leak, but engine wasn't overheating!
Hi guys,
I own a 1994 W124, it's a E280 with an M104 engine. I am new to Mercedes so I am kind of clueless as to how serious this situation is:
Today after coming back from a short drive (10 minutes going, 20 minutes parked, 10 minutes back), and as I was entering the parking, steam started appearing from the front grill. When I stopped and got out to look it was actually spouting both coolant and steam from some valve. Here is the picture of where the coolant and steam came from:
What exactly is it? A pressure valve / backup spout / link ....?
The funny thing is, the engine was at totally normal temperature. at 90 degrees or a hair above. Car has been running on that for months, and I usually look at the gauge and can say that it goes up and down as expected, taking a half a minute or so to edge above 40 degrees when you first start the car and resting between 85 and 95 throughout most drives.
Anyone has any idea what should be plugged in this valve/hole? Is this common? More importantly should I just go and get a replacement "cover" and put it in, marking it off to simply as a failed cover, or was this pressure abnormal and there is a problem with the cooling system I don't know about?
Sam
sampharo is offline
post #2 of 3 (permalink) Old 08-29-2011, 09:59 AM
Kajtek1's Avatar
Quoted: 1227 Post(s)
Shouldn't the end of the hose laying on left side fit into this hole? Son took our W124 so can't check it, but that how it looks like.
Since the opening is on the top of the system you might be able to drive with it for some time. Take the cap off to release any pressure.
Kajtek1 is online now
post #3 of 3 (permalink) Old 08-30-2011, 09:09 AM Thread Starter
Thanks Kajtek
Someone else also pointed out that I am not looking at two connections but that my unfamiliar eye failed to see that this is a broken elbow fitting and it fits into that hole. I extracted both broken parts and will be getting a new 90 degree elbow fitting to connect the hose back into the radiator.
Sam
sampharo is offline
    Overheating for the first time ever, water noise in engine noeltazz W124 E,CE,D,TD Class 9 04-06-2010 10:20 AM
    water leak from engine nickpotgieter W123 E,CE,D,CD,TD,TE Class 3 03-23-2009 10:48 AM
    Oil leak, Overheating and water leaks Help! ( Pictures included ) 8E8E W202 C36 AMG, C43 AMG 1 02-11-2009 07:22 AM
    Coolant problem - engine overheating/leak fix gone wrong half-9 V-Class 0 01-10-2009 05:37 AM
    water leak in w124 janos_z W124 E,CE,D,TD Class 5 10-04-2004 11:15 AM
