Mechanical key and alarm - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-26-2011, 01:05 PM Thread Starter
Date registered: Jun 2011
Vehicle: 2006 SL500, 2015 ML350
Quoted: 4 Post(s)
when I jog in a local park, i like to take the mechanical key and lock the electronic key inside. When I open the door with mechanical key, the alarm goes off and it is very annoying. Is there a way that the alarm doesn't go off? thanks!
mattc6262 is offline
post #2 of 2 (permalink) Old 08-28-2011, 09:18 AM
Kajtek1's Avatar
Quoted: 1223 Post(s)
I was trying to do the same thing going to the beach, but turned out my cylinder lock on the trunk was frozen from no use and I didn't want to leave electronic key inside the cabin. The trunk lock has the option of being double locked, when the blade key comes out in horizontal position and only the blade key can open it after.
Anyway, from what I read the alarm is activated only by the remote. Meaning if you lock the car with mechanical key, the alarm should not come on. Than if it does, putting the key into ignition, or pushing the open button on the remote should quiet it.
Knowing the year and model would be nice, but start with reading the manual since MB likes to change those systems from year to year without a notice.
Kajtek1 is offline
    towing/cabin alarm switch lit all the time :( Alarm faulty Olivier A W210 E-Class 26 06-13-2011 03:08 AM
    Mechanical Key RMZ466 X164 GL-Class 7 02-25-2007 08:51 AM
    Can the factory alarm be codes so that it beeps when the alarm is engaged and the light flash HACK THT W163 M-Class 0 03-18-2006 07:10 PM
    Audio clip of the panic alarm - alarm + Hella air horns... Drew W163 M-Class 0 10-10-2003 06:35 PM
    Mechanical Fan NickT G-Class 5 09-05-2002 06:33 AM
