tired of disconnecting battery - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-26-2011, 11:41 AM Thread Starter
Date registered: Aug 2011
My front seat,door mirror and window take turns on not working when i disconnect an reconnect the battery it all works for maybe 2 days then same problem again. Can someone give me some advise on what this could be I drive a 98 e320
jerry davis is offline
post #2 of 2 (permalink) Old 08-27-2011, 03:44 AM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
When you disconnect the battery you effectively clear the fault code, which allow the item to work, the fault code is the key to finding the cause. Next time one of these items fails to work do not disconnect the battery instead have the fault codes read out with diagnostic equipment and you will then know what needs to be done.
eric242340 is offline
    ABS/ESP/BAS lights came on after disconnecting the battery E320 2001 W210 E-Class 3 07-01-2010 01:02 PM
    Disconnecting the battery Black Stallion W210 E-Class 9 10-02-2005 10:47 PM
    Disconnecting the battery on a 96' E 300 D bob richards W210 E-Class 7 12-20-2004 05:55 AM
    disconnecting the battery on the slk 32 amg............ amgstyle R170 SLK-Class 2 10-03-2002 10:29 PM
    Disconnecting the battery on SLK 32 AMG ??????? amgstyle R170 SLK-Class 0 10-03-2002 09:55 PM
