New member needs glass replacement help - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 08-23-2011, 10:22 PM Thread Starter
Date registered: Aug 2011
I have two Mercedes, a 2001 e320 and a 1998 SLK230.
I've replaced the regulator for the rear window on the e320 before.
It broke again, only this time the glass also broke.
I found replacement OEM glass but can't find sufficient instructions to install it. I only found one post about how this comes apart, and it's incorrect.
Can someone please give me detailed instructions on how to get the glass in?
Driver's side rear door. I assume I need to disconnect the battery and the airbag. Beyond that, nothing's obvious. Thanks so much, I really want to do this myself.
emery16761 is offline
post #2 of 5 (permalink) Old 08-23-2011, 10:36 PM
eric242340's Avatar
Quoted: 309 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - Benzworld.org - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
Give me your vin # and I may be able to post the instuctions
Regards
ERIC.
eric242340 is online now
post #3 of 5 (permalink) Old 08-23-2011, 10:55 PM
eric242340's Avatar
Quoted: 309 Post(s)
I think I have found it, let me know if this is correct.
ID:	393417   Click image for larger version
ID:	393419   Click image for larger version
ERIC.
post #4 of 5 (permalink) Old 08-25-2011, 05:21 AM Thread Starter
Newer model
Hi Eric, thanks for this, it may be sufficient, I'm not sure since I won't have time to check the car til later today or tomorrow. The pictures appear to be of an older model, and my window is a power window.
Mine is a 2001, I guess it's sometimes referred to as W210.
post #5 of 5 (permalink) Old 08-25-2011, 05:27 AM
eric242340's Avatar
Quoted: 309 Post(s)
What I posted is for the 210 model. But if it is different when you come to look at it then give me the vin # and I will look at WIS again.
ERIC.
    Replacement glass gemob General Mercedes-Benz 2 12-28-2009 01:06 PM
    Where to find 79 409 replacement glass? nweuropeanauto Vintage Mercedes-Benz 0 07-08-2009 04:26 PM
    Window Glass Replacement mbj898 W210 E-Class 0 07-08-2007 12:04 AM
    Replacement Mirror Glass ddw1230 W202 C-Class 1 07-28-2005 05:57 AM
    Headlamp Glass Replacement Guest (MBNZ) R129 SL-Class 0 04-15-2002 03:55 PM
