C240voltage - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-22-2011, 07:29 AM Thread Starter
Date registered: Aug 2009
Vehicle: 2004 c240 4 matic
C240voltage
2004 c240 changed original battery due to poor voltage and ac fan shutoff while driving , replaced battery but dyno mode shows 12.3 not running and then when started goes up to 13.0 v and then drops back to around 12. V is this normal or am i in the need for a alternator .
jeffsun21 is offline
post #2 of 3 (permalink) Old 08-22-2011, 09:05 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 68 Post(s)
I'd have that alternator bench-tested to be sure.
flyboyike is offline
post #3 of 3 (permalink) Old 08-22-2011, 09:38 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
There is a decent probability it's the regulator, which is piggybacked onto the alternator and also contains the brushes. After removing the alternator it is quite easy to change.
Good luck.
Check Codes is offline
