dual climate - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-21-2011, 08:33 PM Thread Starter
Date registered: Aug 2011
Vehicle: 2002 E320 Wagon 4Matic
dual climate
My passenger climate control works perfectly hot and cold. Driver's not so good. Just kind of luke warm. Checked duo valve. Not dirty or broke. Other simple checks I can do before going to dealer?
flrt990 is offline
post #2 of 7 (permalink) Old 08-21-2011, 08:55 PM
Kajtek1's Avatar
Quoted: 1250 Post(s)
Welcome to the forum. Your 2002 wagon is W210 body. In W210 section you will find stickies on the top that cover most common problems on those cars including troubleshooting clima system. Looks like you might be low on refrigerant, but don't worry, you come to the best place to help you .
Kajtek1 is offline
post #3 of 7 (permalink) Old 08-21-2011, 09:37 PM Thread Starter
Read stickies. will check for codes. Pass side gets ice cold so refrigerant probably ok.
flrt990 is offline
post #4 of 7 (permalink) Old 08-22-2011, 08:07 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
I'd say the problem is either in your panel or in your driver's side sensor. Or, possibly, both.
flyboyike is offline
post #5 of 7 (permalink) Old 08-22-2011, 08:08 AM Thread Starter
codes for sun sensor, emissions sensor and coolant circulation pump come up. Why does the passenger side work perfectly???
flrt990 is offline
post #6 of 7 (permalink) Old 08-22-2011, 08:09 AM Thread Starter
is drivers sensor easy to replace? how?
flrt990 is offline
post #7 of 7 (permalink) Old 08-24-2011, 06:57 PM Thread Starter
added freon. seems to be better
flrt990 is offline
    Dual Climate control thunder6290 W245 B-Class 43 12-08-2015 07:04 AM
    AC/Heat dual climate controls johndoe1999 W204 C-Class 18 01-07-2014 07:07 PM
    Dual climate not working properly. yorkC320 W203 C-Class 3 01-27-2010 10:27 AM
    What is the big deal with dual climate???? Tom W163 M-Class 13 12-21-2001 07:49 AM
    Why does the SLK have dual climate controls? Cap - Baltimore, MD R170 SLK-Class 9 04-24-2001 08:56 AM
