Window Relay? '88 560 SL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-20-2011, 11:24 AM Thread Starter
Date registered: Aug 2011
Question Window Relay? '88 560 SL
Greetings Forum!
I'm brand new to the MB world and just had my first problem to diagnose. I'll try anything but I'm also not the most mechanical...but I'm eager to learn more... Here's the situation:
Currently, neither power window will work. I figured both fuses probably didn't blow but I replaced them anyway. I did some reading and it seems as though there is a window relay which may be the culprit.
I managed to squeeze down in the passenger side under the dash and pulled what I think is the window relay:
The markings on it are:
On top as shown:
[Mercedes Symbol] 0015420219
Above the three pins: 85 30 87
On right as shown:
12V 20A/30A
Made in
On bottom (not visible in photo)
SR 9850
Above the two pins: 87 85 (I think)
On left side (not visible in photo)
07 and 87 both in circles
On top there seems to be some sort of schematic ...
I'm guess at all of this... so, first, is this the window relay? second, is it likely the culprit? third, is there anyway of testing it? fourth, where would I go to get a replacement part?
I'm looking forward to hearing back... thanks!
markyac is offline
post #2 of 2 (permalink) Old 08-21-2011, 09:40 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
Your Parts Search Returned 1 Part(s)
For $13 replace it anyway.
flyboyike is offline
    window relay hlc W124 E,CE,D,TD Class 1 09-27-2010 11:28 AM
    Window Relay Winston W123 E,CE,D,CD,TD,TE Class 10 08-12-2009 02:10 PM
    window relay zulumack W126 S,SE,SEC,SEL,SD,SDL Class 3 07-11-2006 08:04 PM
    window relay zulumack W126 S,SE,SEC,SEL,SD,SDL Class 1 07-06-2006 03:53 PM
    88 560SL window relay? jaguar13 R/C107 SL/SLC Class 4 07-27-2003 06:18 PM
