Replacing 1998 ML 320 Sun Visor - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 08-17-2011, 02:57 PM Thread Starter
Date registered: Sep 2009
I'm trying to replace a defected sun visor. I have the new visor, but getting to the where the wires end to remove the old visor (see PIC) seems to be a difficult DIY task.
Can anyone give any advice if this is a possible DIY task, or leave it to the experts.Thx for anyone's advice/help.
eyeman03 is offline
post #2 of 7 (permalink) Old 04-27-2012, 12:30 AM
Date registered: Jun 2009
Vehicle: 2005 CLK 500 at 84k miles
Quoted: 7 Post(s)
Send a message via Skype™ to steffen.gutmann
Have you ever gotten a reply? I am about to replace my sun visor right now.
steffen.gutmann is offline
post #3 of 7 (permalink) Old 04-27-2012, 05:26 AM Thread Starter
Nope, I sure didn't. I don't it's a very straightforward job, but a manual might have helped.
eyeman03 is offline
post #4 of 7 (permalink) Old 04-30-2012, 11:04 PM
Quoted: 7 Post(s)
I just spend about an hour trying to disconnect the cable from the sun visor. I can reach the connector through the mounting hole as well as from behind the top panel, but I just can't seem to find the right technique in pulling the connectors apart. Since you seem to have been successful in this, would you mind sharing the trick?
post #5 of 7 (permalink) Old 05-01-2012, 05:23 AM Thread Starter
We both reached the same point. I couldn't get the connectors apart. We have the replacement visor...........just going to have the mechanic put it on.
eyeman03 is offline
post #6 of 7 (permalink) Old 05-01-2012, 09:34 AM
Quoted: 7 Post(s)
I studied the problem a bit more and went through a few related DIYs. I have mine replaced now. I removed the panel of the A pillar. This allows to pull the top panel a bit more and you get better access to the connector from behind. I pulled the connector back until I could see it and used a screwdriver for prying on the clip that holds them. After this the connectors disconnect easily and installation of the new sun visor is straight forward by going in the reverse order. Took about 20 minutes.
post #7 of 7 (permalink) Old 05-01-2012, 09:56 AM
Quoted: 7 Post(s)
I summarized the steps and added an entry to the DIY section of the W163 class. I reused your picture for illustration. See here:
http://www.benzworld.org/forums/w163...ml#post5230955
WTB: vanity/visor lighted mirror, 1998 R129/SL500 IRBSL500 For Sale/Wanted/Trade/Giveaway 0 07-16-2010 10:09 AM
Replacing visor mirror msjkl031 W210 E-Class 4 09-15-2009 11:22 AM
1998 sun visor removal - how squirrelonfire W210 E-Class 6 02-13-2009 10:15 AM
Replacing Mirror in Visor of W164 Motzkoman W164 M-Class 0 07-17-2008 03:01 PM
Replacing Stock HU - 1998 E320 slybydesign W210 E-Class 3 12-10-2007 11:41 AM
