New to Benzworld - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-16-2011, 01:29 PM Thread Starter
Date registered: Aug 2011
Post New to Benzworld
Newbie to Benzworld . I own a 1994 E320 Wagon , Great car !!
I need your help keeping it running 160,000 miles..
Here are some items that I need expert advice on..Thank you for your help !!!
1. Strange occurance check engine light has been on for some time due to codes for egr and upshift dely..recently I noticed the abs and asr lights flickering on and off .they are permenantly on now. steering is a little heavy but brakes work and nim not running in limp mode (the check engine light is now off and no codes are showing) to address the abs/asr, i removed and cleaned wheel sensors (they had black debris attached to them) . disconnected battery for half hour ...dash lights are still on do I properly reset the system and turn out the lights ?
2. lost cruise control at about the same time .
3. lost ac 10 months ago after a refill stayed cold for several days then nothing ...had strange musty smell . Not certain I want to go for a new evaporator core . what are the proper steps to diagnose for sure if the core is gone / any way to repair with out removal?
3a. defroster not performing well seems that moisture appears then burns off after a good while /the more people in the car the longer it takes to clear. smell just a whiff of coolant for a minute or so after turning on ..Any thoughts on how to diagnose this problem.
nomad65 is offline
post #2 of 2 (permalink) Old 08-16-2011, 06:24 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    Thank you BenzWorld wbarp General Mercedes-Benz 3 05-23-2010 08:11 PM
    New to Benzworld! hubmachine General Mercedes-Benz 2 05-08-2010 08:47 PM
    New to Benzworld mrhall General Mercedes-Benz 3 08-08-2009 01:56 PM
    New to Benzworld! davidchett W126 S,SE,SEC,SEL,SD,SDL Class 10 09-10-2006 10:33 PM
    Im new on benzworld. HI! JayBell Off-Topic 220 07-25-2006 12:02 AM
