2002 e320 transmission slipping - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-15-2011, 07:08 AM Thread Starter
nowayjsk's Avatar
Date registered: Dec 2008
Vehicle: 2002 Mercedes E320
Send a message via Yahoo to nowayjsk
Hi, I have a 2002 e320 with a 4matic transmission. I have never had a problem with it until a week ago when I drove it about 50 miles in very hot weather. It was fine until I got off the interstate and came to a stop. The transmission would not engage. I turned it off and restarted a few minutes later. It ran until I had to stop again. I bought a transmission fluid dipstick and found out I was two quarts low. I added fluid but it still won't go into gear once engine heats up. Also the check engine light comes on the minute I hit the brakes. Anyone have any ideas. Your thoughts would be greatly appreciated.
nowayjsk is offline
post #2 of 2 (permalink) Old 08-15-2011, 07:24 AM
Musikmann's Avatar
Quoted: 5 Post(s)
My first thought would be to post this on the W210 forum found in the sedans section. Also we have some sticky threads and there is a lot of transmission related info in there.
Chances are you have the well known leaking electrical connector and some ATF has wicked up into the TCU (transmission control unit). If you're lucky you can replace the plug and clean that thoroughly. Procedure is in those stickys.
Good luck and welcome to the forum.
Musikmann is offline
    2002 E320 4Matic - Transmission Gremlin? Bfamily General Mercedes-Benz 13 06-14-2011 01:51 AM
    2005 E320 CDI Transmission Slipping jkirsch General Mercedes-Benz 2 02-18-2011 08:43 AM
    Transmission Slipping in Cold Weather-'01 E320 95Rover W210 E-Class 18 01-26-2011 02:10 PM
    E320 CDI transmission slipping? kkau W211 E-Class 21 10-11-2010 09:44 PM
    transmission e320 2002 stationwagen robert henrickson General Mercedes-Benz 2 07-21-2010 08:50 AM
