Modify coding to erase SRS code B48 Unit (child seat recognition sensor) - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 08-10-2011, 01:29 AM Thread Starter
Date registered: Mar 2008
Quoted: 5 Post(s)
I changed the coding to show there is no sensor mat in the car and the code I had did not come back up but I did get a different fault code regarding the coding error. Has any one successfully changed coding in order to get the SRS light off?
1999 SL500 155k miles
2003 C32 155k miles
2002 S55 178k miles
2004 S430 210k miles
2003 E320 110k miles
2004 E500 180k miles
2003 E500 120k miles
CarBizIndio is offline
post #2 of 12 (permalink) Old 08-10-2011, 01:54 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Well, yes, but it was on a different care where after other modifications no other option existed. In this case I feel you should fix the sensor.
Did you unplug the sensor cable? Did you try it via special functions or from the developer menu?
Diesel Benz is offline
post #3 of 12 (permalink) Old 08-10-2011, 11:28 PM Thread Starter
Quoted: 5 Post(s)
Thanks, I did every thing except for unplug the connector now my problem is solved. I'm pretty sure I was in the special functions area because I remember not being able to get in to the developer section with out a password
2003 C32 155k miles
2002 S55 178k miles
post #4 of 12 (permalink) Old 08-29-2011, 01:26 PM
Date registered: Feb 2006
Vehicle: 2001-W210-CAPRI METALIC BLUE-/ 2002-W210 E300D
Location: Los Angeles, Ca, Aberdeen Scotland, Lawrence Ks.
Cool Playing with FIRE ???
This is all discussed IN DETAIL, all aspects, and simple repair options in the 210 forum,
PHOTO DIY SRS SEAT SENSOR in the diy section.
Just be aware that by re coding, you are altering the fireing sequence and/or eliminating the air bag system.
You might just have a bad wire, or the real fix in diy is less than 150 U$.
You might want to look in the 210 diy thread.
B
The finest example of automobile engineering in the world
Floats like a CADI
Stings like a BMR
Stingy as a Prius
and.... all Mercedes Benz.
MRBSMITH is offline
post #5 of 12 (permalink) Old 12-22-2011, 12:51 PM Thread Starter
Quoted: 5 Post(s)
I could not locate that topic in the dyi 210 sticky
2003 C32 155k miles
2002 S55 178k miles
post #6 of 12 (permalink) Old 05-08-2015, 10:02 AM
Date registered: May 2015
Quoted: 2 Post(s)
hi i am new to the forum were you ever able to bypass the child seat sensor issue you had by changing the coding if so how did you do it ? thanks ahead
beefyhead1985 is offline
post #7 of 12 (permalink) Old 05-11-2015, 01:46 AM
eric242340's Avatar
Quoted: 296 Post(s)
To change the coding requires the use of DAS, this is the MB diagnostic equipment and it is very expensive. There is another way round this though;
http://www.benzworld.org/forums/10564729-post131.html
ERIC.
eric242340 is offline
post #8 of 12 (permalink) Old 05-11-2015, 10:29 AM
Quoted: 2 Post(s)
i bought one of those emulators plugged it in because the one i bought already had the plug for Ireland, its from an ebay store named airbag 360 anyways i plugged it in cleared the code and the code came back. I used a carsoft scan tool that confirmed everything the dealer said its not a problem with the seat mat sensor but the issue is with the child seat recognition sensor b48 code to be exact. side note i just had my seats reupholstered its a 2003 sl500 the tech at the mercedes dealer claims their is an actual sensor built into the actual seat cover anybody ever heard of this any advice or direction would be appreciated. is it possible that a dealer would do the bypass ?
post #9 of 12 (permalink) Old 05-11-2015, 01:52 PM
Date registered: Jul 2005
Quoted: 976 Post(s)
I can't see a dealer taking the liability of disabled a safety feature.
Noodles is offline
post #10 of 12 (permalink) Old 05-11-2015, 02:16 PM
eric242340's Avatar
Quoted: 296 Post(s)
+1, Not a chance in hell.
ERIC.
    w211 disable child seat recognition sensor pecirepi W211 E-Class 17 10-25-2012 05:03 AM
    child seat sensor W163///AMG W163 M-Class 13 10-31-2011 03:50 PM
    2000 SL500 SRS llight on fault code 31 child seat sensor maplevalleykleemann R129 SL-Class 4 12-04-2009 09:19 AM
    Child Seat Recognition Sensor rickn609 R170 SLK-Class 1 08-23-2009 09:48 AM
    Passenger seat child sensor doncbrown W210 E50 AMG, E55 AMG 1 07-29-2006 11:24 PM
