Overheating - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-09-2011, 07:18 PM Thread Starter
Date registered: Aug 2011
Overheating
Hi all, I am new to the forum, already a great help. My son was given a 1990 300E, 104 that has been sitting for almost two years. He was told the original problem was overheating and the po suspected a bad water pump. I followed the instructions and replaced it in 4 hours. I left the thermostat off. She starts and sounds great but still overheats within 10 minutes. No oil in water or visa versa. Any ideas would be greatly appreciated! P.S. new oil, filter etc.
Thanks
bughunter is offline
post #2 of 3 (permalink) Old 08-09-2011, 08:02 PM
Date registered: Mar 2008
Quoted: 5 Post(s)
go to autozone and get a block tester
http://www.amazon.com/Great-Neck-Block-Tester/dp/B004FELK6A/ref=sr_1_3?ie=UTF8&qid=1312941526&sr=8-3
Don't let it over heat while your diagnosing the problem or you will end up with some major problems if you don't have any yet.
1999 SL500 155k miles
2003 C32 155k miles
2002 S55 178k miles
2004 S430 210k miles
2003 E320 110k miles
2004 E500 180k miles
2003 E500 120k miles
CarBizIndio is offline
post #3 of 3 (permalink) Old 08-10-2011, 03:13 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
How is the radiator?
flyboyike is offline
    Overheating? soundquest W124 E,CE,D,TD Class 83 06-25-2012 09:42 AM
    CLK 320 Overheating Phil D C208/A208 CLK-Class 13 05-28-2010 10:46 PM
    car is still overheating =( netsfan549 W202 C-Class 37 07-09-2009 09:35 AM
    Overheating armyboi4id W126 S,SE,SEC,SEL,SD,SDL Class 32 07-31-2007 01:11 AM
    Overheating f1crazydriver W126 S,SE,SEC,SEL,SD,SDL Class 2 07-31-2005 01:49 AM
