Transmission power flush? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 08-09-2011, 11:37 AM Thread Starter
Date registered: Aug 2011
Vehicle: CLK430 2001 Coupe
With the Transmission power flush done. Do the mechanic need to break the red tap on the cover to refill the fluid?
I just want to know how do I as a consumer know the service had been done for my car?
We had been misbehave on the service in the dealership. Are there the way you can tell if the service transmission power flush had been done for the car?
Don Bui is offline
post #2 of 2 (permalink) Old 08-09-2011, 11:55 AM
Musikmann's Avatar
Quoted: 5 Post(s)
As I understand it, with the power flush the machine flushes out the old and puts in the new through the same ports or tubes. The pan does not come off and consequently, the filter is not changed or the pan gasket replaced. The only reason for the tech to remove/reinstall the lock pin that you are calling the red tap is to check the ATF level and hopefully they did that.
Musikmann is offline
    Transmission Flush? Schweinhund W210 E50 AMG, E55 AMG 16 10-17-2010 11:45 PM
    Power steering flush AlphaWolf W210 E-Class 1 02-13-2008 12:11 PM
    Power flush ATF for transmission flare? MustMakeAmends W124 E,CE,D,TD Class 2 11-01-2006 05:47 PM
    Transmission, to power flush or not Teutone W126 S,SE,SEC,SEL,SD,SDL Class 4 03-27-2006 09:49 AM
    Transmission Flush NorCal_ML320 W163 M-Class 5 03-07-2006 10:31 PM
