A140 with IAT & ABS sensor fault - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-09-2011, 03:07 AM Thread Starter
Date registered: Aug 2011
Hello All, I have an A140 1.4l 2002, and it's driving in limp mode (30mph). The error code showing is :
P0110 Intake Air Temperature Circuit Malfunction.
But the lights showing in the dash when driving are ABS ESP/BAS.
Which sensor should i replace?
The IAT or the ABS sensor?
Rgds
Craig.
craigy1970 is offline
post #2 of 3 (permalink) Old 08-09-2011, 08:38 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 410 Post(s)
I would consider the MAF sensor here.
keyhole is offline
post #3 of 3 (permalink) Old 01-16-2012, 08:28 AM Thread Starter
Hi, Its been a while, but a quick update on the above.
I replaced the ABS ring on one side which had broken. It has solved the limp mode issue and put the ABS light out.
Just to be clear on the MAF sensor.
The error code P0110 is for the Air intake temp sensor!
Is the Air intake sensor and MAF the same thing, or two different sensors?
Thanks
Craig.
Yaw sensor fault Chris A R170 SLK-Class 6 11-14-2009 06:37 PM
O2 Sensor fault code no. 17 coma R129 SL-Class 0 05-27-2009 11:06 PM
A140 Mileage Display Unit fault km2007 W168 A-Class 3 01-23-2009 02:02 AM
rain sensor possible fault moyapizda W163 M-Class 6 03-13-2008 01:57 PM
air recirculation fault A140? LEOA140 W168 A-Class 0 11-20-2006 09:16 AM
