1987 Mercedes 300E Ignition Switch - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 08-06-2011, 08:31 AM Thread Starter
Date registered: Aug 2011
I have a 1987 Mercedes 300E (gas). The ignition locked-up which I have learned is a very common problem.
I have a new housing, tumbler and switch. On the back of the switch are 7 places where wires plug on. They are numbered 30, 50, 15R, P30, 15, 30, 15X.
Because the original switch had locked, I couldn't turn the key to the right position so that the wire plug can come out of the ignition switch housing, therefore the wires had to be forced apart.
Do you have a list or diagram that tells which color coded wire goes to which number? Thanks for your help!
Ok, My ignition wires are the following colors:
2 Red wires
1 white w green stripe
1 white w yellow stripe
1 white w red stripe
1 purple w white stripe
1 green w white stripe
Clock wise on the switch the number code goes
So what color wire goes where?
30 =
15x =
30 =
15 =
P30 =
15R =
50 =
Please help....
Kazz is offline
    300E ignition switch papadude21 W124 E,CE,D,TD Class 11 01-01-2011 01:13 PM
    1987 280GE Ignition switch cdriza Vintage Mercedes-Benz 2 05-11-2009 11:53 AM
    1990 300E Ignition switch collar frobi W124 E,CE,D,TD Class 12 05-10-2009 07:36 AM
    1987 300TD Ignition Switch Replacement jteleky W124 E,CE,D,TD Class 1 04-28-2009 06:09 PM
    Ignition switch jammed (300E) woodroots General Mercedes-Benz 4 06-30-2005 08:41 PM
