Coolant Change - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-01-2011, 11:28 AM Thread Starter
Mercedes Benz of Florida's Avatar
Date registered: Dec 2006
Vehicle: 2000 Mercedes-Benz S500. Sold: 2000 C230K, Sold: 1997 Porsche 944S
Quoted: 26 Post(s)
Send a message via Yahoo to Mercedes Benz of Florida
Coolant Change
So here I am, preparing for a trip from the South to the North, so I get this crazy Idea to change out my Oil. So I did, Mobil 1, 6.2 Quarts. I also had the Tires Rotated and then Rebalanced.
Then I get this other crazy Idea. Coolant Change. So I did. DIY.
I flushed the Radiator for 30 Minutes, off and on, off and on, car on, car off, with heater on. I spent a good long time on her. I installed the Factory Anti Freeze along with Distilled water, a 70/30 Mix.
I took her for a short drive, no Oil leaks, no Coolant burps or anything.
So I take a 25 Minute drive to the Bank, and what happens?
She starts SPUTTERING! Gagging! I could barely get 25MPH on the local highway! Temperature Gauge is where it should be. Check Engine Light comes on. ( I should have pulled the Codes BEFORE I wrote this yes? )
Guys: Is there an Air Bleed Screw I do not know about?
Do you think, there is Air trapped in the system?
Could that be causing the chugging?
Can anyone share any pictures of the possible air bleed screw/bolt?
Ref: 2000 C230 Kompressor, 108, 238 Miles.
Mea culpa, Mea Culpa. Somebody help!
Charles
New York City, NY
Richmond County
United States of America
Mercedes Benz of Florida is offline
post #2 of 3 (permalink) Old 08-01-2011, 11:31 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Assuming you did nothing wrong in the process, that wouldn't account for those symptoms. The most likely thing is that either you accidentally knocked something loose (or maybe cracked a connector that broke) while you were doing your maintenance, or else it's something unrelated that was just a mere coincidence.
Either way, you're right, you should have first checked for codes.
Check Codes is offline
post #3 of 3 (permalink) Old 08-01-2011, 11:51 AM Thread Starter
Quoted: 26 Post(s)
gregs210-yeah, I knew I was going to be busted on that note!
I will wait for the ol' gal to cool down some bit and get the codes.
Your right about knocking a hose loose here or there.
Hopefully CEL Code will let me know and I will quickly find out!
Better here, locally, at home than on the road!
Thanks.
Charles
New York City, NY
Richmond County
    230 SLK Coolant change Veloman R170 SLK-Class 6 05-30-2010 07:03 PM
    How often do you change your coolant? bavenda W163 M-Class 9 03-12-2007 07:54 PM
    Time for coolant change - which coolant? oberoi R170 SLK-Class 10 11-13-2006 02:51 PM
    coolant change diesaroo W201 190-Class 6 10-20-2006 08:45 PM
    coolant change w210 W210 E-Class 6 07-04-2005 10:30 PM
