sl500 lumbar not working - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 08-01-2011, 10:23 AM Thread Starter
Date registered: Aug 2011
Just got my 2004 sl500 out of the repair shop. They replaced the PSE pump and trunk lock mechanism due to the soft close not working. Prior to bringing the vehicle in the lumbar worked on both seats, however, it is not working now. Brought it back and they are trying to say it is unrelated--they allegedly checked the fuse and areas that they worked in and as a result they said I need to make a new appoint for the repairs. I am quite confident that it has something to do with the work they performed--I looked at the pump and did not see anything disconnected. The lumbar dial for both seats does nothing at all. It's almost as if they are both completely disconnected. I was unable to locate a fuse on the diagram for the lumbar so I have no idea which fuse to check. Any help would be appreciated.
benzsl500 is offline
post #2 of 3 (permalink) Old 08-01-2011, 12:12 PM
Diesel Benz's Avatar
Quoted: 37 Post(s)
If the workshop only changed the PSE pump and the trunk lock mechanism, they might have version coded the PSE unit incorrectly. The PSE unit has a setting for the multicontour backrest or the lumbar support, perhaps this was incorrectly coded.
Diesel Benz is offline
post #3 of 3 (permalink) Old 08-01-2011, 12:38 PM Thread Starter
Thank you. I will see if the dealer is willing to check the coding on the PSE.
    PLS HELP ... W221 Lumbar Seat not working ... bhartv W221 S-Class 18 05-14-2015 05:56 PM
    SL500 In-car phone not working - HELP! RodSL500 Audio & Telematics Forum 10 05-09-2010 12:12 PM
    Driver's Lumbar Contour Now Not Working slk55er X204 GLK-Class 2 03-15-2010 10:17 AM
    sl500 windows not working uk_ R129 SL-Class 1 10-22-2007 11:42 AM
    92 SL500 A/C Not working scorpiox R129 SL-Class 1 05-19-2007 02:37 PM
