Sluggish 83' 300SD - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-30-2011, 06:37 PM Thread Starter
Date registered: Jul 2011
Vehicle: 1983 300SD Turbo 180k mi
Post Sluggish 83' 300SD
I just bought an 83' 300SD that was set up to run vegetable oil. I have had it reconfigured to only run DF now. The first time that it was sluggish we took it to the shop and they changed out all the filters. Then it happened again and we took it back to the same shop. The mechanic said that there was "sludge" in the filters so he thought that maybe there was "sludge" in the fuel tank as well, maybe from residue left behind from the vege? Anyway, He found a "clean" used tank from another 300SD that only used diesel fuel, so he switched out the tank and replaced the filters again. We thought that the problem was solved. However we got the car home yesterday and went out for a test drive today and again it is very sluggish, practically no power on hills, slowing down from 45 to 20. The pedel all the way to the floor, RPMs at 20. It almost feels like it needs to down shift. Is it possible that there is more sludge in the fuel system somewhere. Is there a fuel additive that I can use to clean out the fuel system? Any other suggestions?
Last edited by ksabrinaj; 07-30-2011 at 07:18 PM. Reason: needed to add more information
ksabrinaj is offline
post #2 of 2 (permalink) Old 07-31-2011, 06:52 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld
eric242340 is offline
    SLK 230 Sluggish aceangel R170 SLK-Class 9 04-13-2006 10:22 AM
    sluggish brake hakkaloong G-Class 9 01-25-2006 07:23 AM
    sluggish performance??? Dolphin27 R170 SLK-Class 4 01-01-2006 07:22 PM
    ML 320 a bit sluggish? laxman0324 W163 M-Class 9 11-26-2005 05:27 PM
    sluggish on take off! MANDERSON W126 S,SE,SEC,SEL,SD,SDL Class 3 06-17-2004 08:13 PM
