new to forum - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-30-2011, 06:03 PM Thread Starter
Date registered: Jul 2011
new to forum
i have a 1998 ML 320. Kind of regret buying it. ive had it for about one year and 4 months. ive had a few problems with it. first off i noticed a water leak during the rain. water would leak on to the front passanger floor from under the dash. i found out there wasnt enough sealant under the ski rack on the a-frame. patched it up and no more leak. also the water drain was clogged with leaves causing a wooshing osund everytime i turned. my rear bench seat doesnt fold down all the way to the floor anymore. seems like the rod is bent and wont lock. and the latest problem i have is that there is sludgy oil in the oil coolant reservoir. im assuming its the oil cooler and i have found a thread about that same problem. if i were you dont buy this car, or at least a 1998.
polobenz is offline
post #2 of 2 (permalink) Old 07-31-2011, 06:49 PM
eric242340's Avatar
Quoted: 283 Post(s)
Welcome to Benzworld. Please complete your profile as this will help members give you the most accurate answer to your questions. Location is also important when we need to help you find parts etc. This forum is for introductions only and all questions should be posted on the appropriate sub forum for your car.
To edit your profile simply click on quick links “edit profile” (quick links is top Right of the page)
At the bottom of the page you will find forum jump, click on this and view all the available sub forums and there you will find the technical forum for your car.
For FAQ see the Benzworld help section here:
BenzWorld Help - - Mercedes-Benz Discussion Forum
Benzworld help is for general enquires and all technical questions should be posted on the specific forum for your car. If you are not sure which forum it should be on then please ask me and I will give you a link.
eric242340 is offline
    Joiner to the 211 forum from the 107 forum just down the hall... cctoronto W211 E-Class 2 12-02-2010 08:25 PM
    Can you recommned me a BMW 3 series Forum as good as our BenzWorld W-163 M forum? erikluca W163 M-Class 8 05-25-2008 09:29 PM
    OT: Sorry, I realize that there is a forum for that, but scores of people on this forum tcp_ML500 W163 M-Class 10 10-17-2003 12:41 PM
    To those asking, the G-Class forum and Unimog Forum are now active. Frank W163 M-Class 0 08-12-2002 04:54 PM
    Just noticed that there is a forum for the C32. I do enjoy all the SLK's in the same forum, but... Marc32 R170 SLK-Class 19 02-22-2002 06:35 PM
