1991 350SD - AC (Air Conditioning) and center vents not operating mystery - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-29-2011, 01:07 PM Thread Starter
Date registered: Jul 2011
Hi all,
The AC and center vents on my neighbors 1991 350SD quit.
The AC has a full charge and the fuse is OK. If the low pressure switch terminals are touched together, the compressor will still not click on. Is there a relay that I am missing?
Also, the center vents on the 350SD are not operating. If i remember from looking at oie in the boneyard, there are some electric/vacuum switches behind the push button panel. Are these a source of failure?
This is quite different from my servo based 300TD ACC!
Any help is appreciated! Thanks!
mattmondo is offline
    Update on AC center vents repair (no air from center vents) Goatman W140 S-Class 11 11-28-2011 02:12 PM
    new toy: 1991 350SD srh11293 W126 S,SE,SEC,SEL,SD,SDL Class 2 05-27-2011 12:08 AM
    Air Conditioning Center Vents Problem houston14 R/C107 SL/SLC Class 5 06-07-2007 03:17 PM
    Air won`t blow from center vents, only from defrost and side vents on dash??? johnstonmurray R/C107 SL/SLC Class 3 11-21-2006 01:38 AM
    non-operating center vents; and K & N airfilter tresean1 W202 C-Class 3 02-20-2006 03:27 AM
