S500 hvac problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 07-24-2011, 06:09 PM Thread Starter
Date registered: Jul 2011
S500 hvac problem
Hi, I am new to benzworld. I have a 2004 S500 4-matic with rear a/c (220.184). The symptoms are, when the a/c is on I have cold air coming from the front center vents only, and colder from the left center vent. In the rear I have cold air from the rear left vent and hot air from the rear right vent. A scan of the rear a/c controller gives me codes; B1426-A31/1m1 (circulation pump) and B1429-RR duo valve A31/1y2. I can not clear the Codes, they are hard codes. I suspect I have a problem in the front hvac and a different problem in the rear hvac. There is a duo valve in the Driverside rear engine compartment and a duo valve in the front right wheel well which I believe is for the rear hvac. I suspect I have a sticky rear duo valve on the right. Can anybody help me with the problem. Also, does anybody know if the front and rear duo valves are the same and interchangeable. Thanks in advance.
Mrhooper is offline
post #2 of 3 (permalink) Old 07-24-2011, 06:34 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Common problem for duovalves to stick. Inspect/clean them to see if that helps. After cleaning move them by hand to make sure they move freely.
Musikmann is offline
post #3 of 3 (permalink) Old 07-26-2011, 01:04 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 394 Post(s)
MrH
I think that you can initially progress this fault without dismantling components by checking the temperature (by hand) of the hoses in the front/rear duovalve systems. If cold, after a suitable warm up period, there might be a problem with the duovalves.
These drawings should help you get your bearings. As you know, the rear duovalves are behind the right front fender, so you will have to remove the wheel & the fender inner liner to get at it.
keyhole is online now
    HVAC Problem 86 560sec rock01 W126 S,SE,SEC,SEL,SD,SDL Class 2 01-27-2011 11:34 PM
    Really need help with HVAC problem 635CSi W126 S,SE,SEC,SEL,SD,SDL Class 4 12-10-2010 06:44 AM
    HVAC problem jstetor53 C209/A209 CLK-Class 1 05-10-2010 12:35 PM
    Odd problem with my HVAC system...maybe you could help? W140FTW W140 S-Class 1 01-04-2008 11:59 AM
    HVAC Problem RichardV G-Class 4 03-15-2002 06:07 AM
