ML350 AC stops cooling - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-24-2011, 03:31 PM Thread Starter
Date registered: Jul 2011
Vehicle: 2005 ML350
I have a 2005 ML350 with 108000 miles. The AC seems to have a mind of its own. I can set it on the coldest setting and it may cool for several hours just fine and suddenly it will feel like the temp. setting is being moved over to the hottest setting. Sometimes when I start the car it will not cool at all. Just depends on what mood its in. Usually we can get it to start cooling again by turning the ac on and off, or by changing the temp setting from coldest to hottest repeatedly or by holding the auto button until the temp resets. One method doesn't seem to work any better than another, it will just start blowing cold again until it changes its mind again. I've read several post on here about this problem. Not sure if its the blend door or the temp sensor or something else. I don't hear any clicking noise in the dash as described by some. It happens in both manual and auto setting. Nothing in particular seems to trigger the problem. I have had the refrigerant checked and that is ok. I would appreciate any help that anyone can give.
GinsML350 is offline
post #2 of 2 (permalink) Old 08-06-2012, 12:05 PM
Date registered: May 2012
Vehicle: ML350 2007
got the same. issue seems to tend to happen in humid weather.
any suggestion? perhaps some AC climate sensor misbehavior
gublman is offline
    Front left signal light works, then stops, then works, then stops...Bulb is fine... rabusalman W203 C-Class 6 03-23-2010 03:19 PM
    Cooling Cooling Fan does not come on as Temperature rises nichor R170 SLK-Class 1 08-16-2009 04:31 AM
    will nerf bars on a 2000 ml350 fit a 2004 ml350? busoptr W163 M-Class 0 01-02-2009 09:55 PM
    Wiper stops, radiator fan stops, indicators ok... Haku W202 C-Class 5 05-29-2008 04:30 AM
    Odometers Works, then Stops, then Works, then Stops......... dieselbenzfan123 W123 E,CE,D,CD,TD,TE Class 6 04-06-2008 07:47 AM
