Power Window on 89/260E Blown Fuse - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 07-24-2011, 10:04 AM Thread Starter
Date registered: Jul 2011
OK.. everything looks good behind the door. Curious where the most common trouble point is for this problem. The windows work just fine except that I blow the fuse after the key is on on the drivers side front and pass side rear. Wondering if the problem could be in or under the fuse box itself. Help, please. This is really the only problem that I am having. Except...
Where can I buy an inexpensive I cluster? The odometer stopped working and I'd rather buy a new/ used one. How much is a used cluster? Thanks again. I will keep you posted on my (hopeful) progess
Dave145009 is offline
    2000 ML 320 Lighter Fuse Blown | Which fuse do I replace? Patkar g_patkar W163 M-Class 12 05-21-2016 07:44 PM
    Window wont roll up, Diagram of fuse box, which fuse is for the power windows? gpacheco101 R/C107 SL/SLC Class 8 03-09-2010 07:49 AM
    Blown Fuse billtodd R230 SL-Class 0 03-02-2009 12:08 PM
    1985 380se power window fuse blown freewheelin franklin W126 S,SE,SEC,SEL,SD,SDL Class 6 06-09-2008 08:45 AM
    Blown Fan Fuse in 85 SEC Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 04-26-2001 06:32 AM
