W211 E270 CDI in limp mode with no fault code - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 07-23-2011, 11:10 AM Thread Starter
Date registered: Jul 2011
Vehicle: W211 E270
I have a 2002 W211 E270 CDI (125.000km) with sequential gearbox. Since a few days when I start the engine the car goes into limp mode switching into manual and 2500 rpm max with no message at all from the on board computer. If after 5 minutes I stop the engine and wait for 10-15" with the ignition off, the car will start again and runs fine.
I had a similar problem years ago, when the car was still under warranty and after changing tons of parts it was fixed by replacing the catalyzers. This probably happened since I was driving the car for sometime in Egypt, where diesel fuel is meant to be used for heavy trucks and not passengers cars.
This is the first thing I did this time too with no success (cleared both cats).
Then I has a MB dealer testing the car and the diagnostic was: faulty transmission control unit. But they didn't ensure me that replacing the unit will fix the problem.
I have the feeling that the problem stands elsewhere. Maybe a clogged EGR valve?
Any suggestion based on your experience?
Best regards,
enzop is offline
post #2 of 2 (permalink) Old 07-23-2011, 07:57 PM
Kajtek1's Avatar
Quoted: 1058 Post(s)
Can't help you with your engine or Egypt fuel , but transmission codes need to be read by Star computer. You will not see them on the cluster, although W211 do have mysterious engineering mode that allows some access to computer data.
Kajtek1 is offline
    ASR fault and Limp home mode macattack56 W140 S-Class 3 04-28-2010 04:43 PM
    Limp mode but no fault codes voodoo123uk V-Class 9 10-27-2009 11:43 AM
    E270 CDI protection mode fault cristian W211 E-Class 4 07-17-2009 05:12 AM
    ASR-fault. Limp mode Eirik 400 SE W140 S-Class 39 05-02-2009 11:34 AM
    Fault code clearing/limp-mode issue K&C124 W124 E,CE,D,TD Class 1 09-10-2005 10:04 AM
